Thermostat housing
wschneid
Thermostat housing
Post by wschneid »
I have an 86 32' sedan flybridge with the 318 Chrysler engines. I want to check the thermostat, but I'm not sure where it is located.
Could someone post a photo of the housing? I see a number of hoses going into a fitting with two bolts near the front of the engine. Is that it?
Any recomendations on removing it?
Bill Schneider
wschneid
Re: Thermostat housing
Post by wschneid »
I have an 86 32' Sedan Flybridge with the 318 Chrysler engines. I want to check the thermostats, but I'm not sure where the housing is located. Could someone post a photo of the location? I see a fitting forward of the carburetor with hoses running to it. Is that it?
Does anyone have any recommendations on how to remove it?
Bill Schneider
Post by TinLizzy »
It is located at the top front of the engine right in front of the carb. Pull the hoses off, and remove the bolts. You may need to tap it with a hammer or such to get it to pop free. There should be a gasket there also.
wschneid
Post by wschneid »
Thanks. that's what i thought.
Bill Schneider
