Engine Synchronizer Issue
Well the last time we were out our flybridge engine synchronizer started going to the port but the may not have been slowing down. Not sure if there is a short or has a short or a bad sending unit. Also our lower station synchronizer works intermittently. Any thoughts?
Trower Power
Blue Sky
Performance Distributors
750 Edlebrocks
fresh water cooled
1.5 to 1 velva-drives
Onan 6.5kw gen set
Blue Sky
750 Edlebrocks
fresh water cooled
Onan 6.5kw gen set
Re: Engine Synchronizer Issue
I would check grounding and power connections first. Isolate problem by disconnecting upper,then lower helm sync checking each unit with other disconnected. Good luck.
1986 Sedan Flybridge
Twin 318 closed loop
" Little Martha"
Traverse City,Mi
Autopilot (both helms)
" Little Martha"
Traverse City,Mi
Thanks for the reply. Will let you know what I find next week.
Greg
Greg
Trower Power
Blue Sky
750 Edlebrocks
fresh water cooled
Onan 6.5kw gen set
Blue Sky
750 Edlebrocks
fresh water cooled
Onan 6.5kw gen set
