Having trouble with distributor cap hold down
My distributor hold down system is the stlye that uses a straight screw driver screw to tighten. The cap down. Anyone have a lead on where to buy them? Having trouble with play in the cap. Its a 1973 318 .
Jeff Monday (Blue Mondays)
Lower River rd
Rabbit Hash KY
Lower River rd
Rabbit Hash KY
Re: Having trouble with distributor cap hold down
You're saying the screw won't tighten up enough to hold the cap down?
Yes. Or the cap is an automotive cap. Not sure so i would like to start with the correct parts on both. It has the old point system out and the electronic style of some kind in and i have a miss on top end. I have changed the timing and it helped for a day but then changed. Something is moving or breaking down. Just trying to find it.
Lower River rd
Rabbit Hash KY
Lower River rd
Rabbit Hash KY
If you have the Chrysler electronic ignition system, check the reluctor and make sure it is tight. The timing on ours was jumping all over and found a loose reluctor to be the cause.
Great thats a start. Thanks
Lower River rd
Rabbit Hash KY
Lower River rd
Rabbit Hash KY
Hey Eric it looks to be a pertronics style but thanks anyway.
Lower River rd
Rabbit Hash KY
Lower River rd
Rabbit Hash KY
You can go to the Vendors list on this site or go to,jmonday wrote:Hey Eric it looks to be a pertronics style but thanks anyway.
http://www.hurrikain.com/
Chrysler inboards
"ignition systems"
And then please add a signature to your post.
The advancing mechanism tends to stick, which makes timing the motor at idle incorrect--the advance didn't come back to the idle position. That makes the motor retarded at WOT.
A few drops of oil on the wick under the rotor, followed by a few minutes of flipping the advance back and forth with one's fingers, often cures this problem.
Thanks Jeff that was the ptoblem with mine. Im now helping a friend up the river a ways. Motor was running bad on starboard side so i swapped the dizzy do you know if i have to change position of the reluctor?
Lower River rd
Rabbit Hash KY
Lower River rd
Rabbit Hash KY
No change to reluctor is required.
safe harbors,
safe harbors,
