Help! Scentry 410 Vapor Sensor
Posted: Sun Jun 30, 2019 5:19 pm
by Studini
So I'm not sure if I've turned the switch on before but apparently I did last night as we woke up with the Explosion light and alarm going off. The power button or test button do not work on the unit so I'm not sure it even works. BUT I did fill up yesterday but could not smell any gas when I opened the engine hatches and after airing everything out the alarm still continued. Anyone know how this is supposed to operate or have suggestion?
Re: Help! Scentry 410 Vapor Sensor
Posted: Sun Jun 30, 2019 10:04 pm
I tried to help by searching for a manual online - no luck. If it's a CO detector, you wouldn't smell fumes since CO is odorless. If it's gasoline vapor detector your fillup might explain the alarm but it should have turned off when you aired out the boat. If I were in charge, I'd replace it -maybe try to check with mfr first- because fumes are nothing to mess with. UPDATE: ANother google search indicates this is an Aqua Meter product most likely long discontinued. Maybe Aqua Meter is kaput also.
I tried to help by searching for a manual online - no luck. If the gas is CO, you wouldn't smell fumes since CO is odorless. If it's a gasoline vapor detector your fillup might explain the alarm but it should have turned off when you aired out the boat. If I were in charge, I'd replace it -maybe try to check with mfr first- because fumes are nothing to mess with. UPDATE: Another google search indicates this is an Aqua Meter product most likely long discontinued. Maybe Aqua Meter is kaput also.
Posted: Mon Jul 01, 2019 7:10 am
Those sensors have a tough life 'down there' and need replacement every few years.
I had JUST replaced mine when, and we were just out of the marina when the fool thing went off. "Nuisance trip," I snorted and opened the hatch just to be sure. Holy crap! Fuel was shooting out of my brand new fuel pump (from a bad weld) and threatening to blow us up! (This was a 32 sedan, and we were standing over the bomb.) Needless to say I replaced the sensor every few years, and tested it every spring.
Posted: Mon Jul 01, 2019 1:01 pm
by Studini
Fastjeff where was the sensor located at in the bilge??
Posted: Mon Jul 01, 2019 5:23 pm
About 6 inches above the bottom. Nasty place!
Posted: Tue Jul 02, 2019 7:47 am
by barkleydave
Do not depend on the test button on the monitor... it only tests the head not the sensor!
Check every season. Place sensor low in the bilge but high enough where it will not get wet. They do not do well when submerged.
Test the sensor with a butane lighter (Not Lit)
Flick your lighter outside in the clear and blow out the flame and keep the button pressed.
Put under sensor and it should set off alarm in a few seconds. If not failed and replace!
Posted: Tue Jul 02, 2019 11:25 am
by Studini
Anyone know where I can get a new sensor?
Posted: Tue Jul 02, 2019 11:55 am
Got mine at West Marine.
Posted: Tue Jul 02, 2019 2:35 pm
https://www.westmarine.com/search?Ntt=fume%20detector
(cheaper elsewhere such as Amazon)
you need a fume (gasoline vapor) detector down below and a CO detector above. Whatever the price they are CHEAP because...you know why
