Ignition coil replacement?
SunbeamIV
Postby SunbeamIV » Thu May 09, 2019 10:33 am
Both of the engines stall at low idle once the get warmed up. Usually right after I’m out running on the lake and the come inside the breakwall ready to dock. When I first start them, they idle fine. I’ve read in other posts that this could be caused by weak coils.
I did a tune up on both engines and the problem is still happening. I’m thinking of replacing the coils as a place to start. Does anyone have any suggestions for replacements?
Located: Edgewater Yacht Club
Lake Erie
Re: Ignition coil replacement?
Postby barkleydave » Sun May 12, 2019 9:09 am
Coils not your problem
Carb issues most likely
