1962 wiring/gauge questions
shelbygt
Post by shelbygt »
Trying to get my arms around things before I tear into it. I have 2 sets of gauges/controls, forward and aft. Forward gauges kinda work although they register on the low side, I think. Did some quick checks with my multimeter and found that both forward and aft gauges had 12v power simultaneously. I don't think they both should as the gauges are electric (with sending units). If both sets of gauges are powered the signal from the sending units for oil pressure and water temperature would be split, which I don't believe can be right. Also, it seemed that forward gauges are postive ground (these gauges work). The aft gauges are negative ground and don't work. I may have had enough beer by that time and was confused???? Would it be positive ground in 1962?? I know older cars are positive ground but I thought most manufactures had switched to negative ground some time during the 1950's.
1962 Marinette 31' Express
Single Gray Marine AMC 327
Mercury 500
1976 Saquaro Jet Boat
Ford 460
Re: 1962 wiring/gauge questions
With dual stations. you have to use dual station sender units or the readings are whacko.
shelbygt
Post by shelbygt »
Hadn't heard of that. Would I go to the gauge manufacturer for that?
Mercury 500
Ford 460
shelbygt
Post by shelbygt »
Fastjeff wrote:With dual stations. you have to use dual station sender units or the readings are whacko.
Jeff,
Do you mean two sending units or a sending unit that can feed two gauges?
Mercury 500
Ford 460
shelbygt wrote:Hadn't heard of that. Would I go to the gauge manufacturer for that?
shelbygt,
Try http://www.hurrikain.com
look under thermostats. :) also you can call and talk to owner. :o He is very knowledgable on
Chrysler Marine Engines :idea:
Temp Sending unit dual station include's adapters
3675703K
shelbygt
Post by shelbygt »
shelbygt,
Try http://www.hurrikane.com
3675703K
Hurrikane.com switches to a site dealing with GoPro, photography, etc. Not seeing anything to do with boating?
Mercury 500
Ford 460
shelbygt
Post by shelbygt »
shelbygt,
3675703K
Worse yet my motor is an AMC 327. And you Chrysler guys thought you had it rough. :D
I thought I was cursed being a Ford guy. :o
Mercury 500
Ford 460
shelbygt
Post by shelbygt »
As it turns out the water and oil gauges were originally wired in parallel. I'm ordering all new gauges and dual station senders. Doubt they had dual station back in the day. Will re-wire individual circuits.
OBTW. VDO has been very helpful and seem to cater to the marine industry. I normally run Auto Meter but I'm running VDO based upon their helpfulness.
Mercury 500
Ford 460
shelbygt wrote:
shelbygt,
3675703K
Hurrikane.com switches to a site dealing with GoPro, photography, etc. Not seeing anything to do with boating?[/quot
Sorry about that the correct email would be:
