lower helm removal 1985 39'
hoohaah
Postby hoohaah » Thu Feb 15, 2018 1:07 pm
I would like to remove the lower helm steering hub & cannot figure out how to remove the wood panel its attached too? There must be hidden fasteners I cannot find. I removed the pannal in the cupboard above the sink I can see the hub of the helm but not any fasteners? Any advice would be appreciated.
Thanks for looking
Wally
[img][urlwww.]gldocks.com[/url][/img]Wally D
Name HOOHAAH..TOO!!
Great Lakes Docks & Decks with over 30 years in Marine Construction & boat hoist sales Location Algonac, MI
yooper
Re: lower helm removal 1985 39'
Postby yooper » Thu Feb 15, 2018 2:22 pm
Need some pictures. On the 32' you take off the wheel. Unscrew 4 big bolts, take off the big ring washer and push the hydraulic pump unit out the back. Do not take off any hoses.
hoohaah
Postby hoohaah » Thu Feb 15, 2018 3:01 pm
Cable steering, I,ll try to take some pictures this weekend thanks
Name HOOHAAH..TOO!!
RBrown
Postby RBrown » Thu Feb 15, 2018 4:46 pm
We removed the spice rack that is below the upper cabinet to gain access. There is a set screw in the bottom of our hub. If you loosen it you can pull the shaft with the drum out the back.
Rob
Misty Blue
350 HP. Crusaders
Home Port: New Buffalo, MI.
hoohaah
Postby hoohaah » Fri Feb 16, 2018 7:10 am
Thank you Rob
Name HOOHAAH..TOO!!
