solenoid
solenoid
Postby ddependo » Tue Oct 11, 2016 7:05 am
Old wise Marinette men, Is there a "marine" solenoid or same as automotive?
Re: solenoid
Postby ericinga » Tue Oct 11, 2016 2:17 pm
I've compared the two versions and couldn't find a difference. I use the automotive version.
Wilfred
Re: solenoid
Postby Wilfred » Tue Oct 11, 2016 9:12 pm
Same part number as what was on boat and what is spec for a 1970 Ford
Got mine at NAPA
W. J. Brockman
1984 Marinette Express Bridge
Twin 318s 235 hp
Bolles Harbor, Michigan
Re: solenoid
Postby barkleydave » Wed Oct 12, 2016 7:48 am
The question is: Is it marked "Ignition Protected"? If UL approved it will be marked. If no,t you could be making a dangerous assumption. Also the one that is "Marine" will have better corrosion protection (copper, nickel etc) on the terminals for the marine environment.
SAE J1171 approval
Wilfred
Re: solenoid
Postby Wilfred » Wed Oct 12, 2016 10:54 pm
A Sierra Marine 58-1841 part number, seems to fit LM318, widely available
I needed one quickly so I got one @ NAPA
Yes, use of non-Marine grade electrical engine components..DANGEROUS
W. J. Brockman
Twin 318s 235 hp
Re: solenoid
Postby Fastjeff » Sat Oct 15, 2016 5:46 am
There's two varieties of these things: Those meant for starting the engine, and those that are a remote switch (left on) for paralleling the batteries. The latter is 'soft' energizing and can be left on without damage.
spdracer
Re: solenoid
Postby spdracer » Sun Oct 23, 2016 8:49 am
The automotive solenoids do not have a long enough bracket to use both mounting bolts. Other than that they work just fine and are safe to use.
Chris Hamann
Lakeland Auto & Marine
Port Clinton, Ohio
Leviathon
Re: solenoid
Postby Leviathon » Mon Oct 24, 2016 3:28 pm
Hey Fastjeff,
Question on those other solenoids with battery cables running to them. That is the first time I have seen that on my "new to me" marinette. Necessary? Still do not completely understand the purpose and have seen the set up without.
Steve and Mary Levi
1973 32' Marinette Fisherman
SBC Crusaders
El Ohssa
St. Joseph, Michigan
Re: solenoid
Postby bill » Mon Oct 24, 2016 7:41 pm
Steve,
On my 1975 37 Marinette with two batteries and one of those batteries runs all the 12 volt stuff. Some times the house battery drains down one battery and the engine wont turn over. :oops: There is a parallel switch on the lower helm, it looks like a silver horn push button. :D This actuates the parallel solenoid switch in the engine compartment. ;) Just like jumping a dead car battery but with press of a button instead of jumper cables :lol: .
USCG Master Lic. Retired
Leviathon
Re: solenoid
Postby Leviathon » Mon Oct 24, 2016 8:58 pm
Alright - will search for the silver button to see if I have the same - thanks Bill.
S
Steve and Mary Levi
SBC Crusaders
El Ohssa
