running engines on the hard?
RustyBoat
Post by RustyBoat »
I plan on firing up my engines for the first time this fall on the hard. That is after I let the cylinders soak with oil for a few days and a tune up. What's the best way to start the motors and run till normal operating temp on the hard?
Is it as easy as disconnecting the water intake hose after the strainer and putting a water hose inside the hose?
Is there a certain RPM I shouldn't exceed?
1968 32' Fisherman
Lake Sidney Lanier
Re: running engines on the hard?
What I do is disconnect the hose from the seacock at the strainer. I have a longer piece of hose to put on the strainer that goes into a 5 gallon bucket. If you put the correct size bit in a cordless drill this is real quick and easy. Put the garden hose in bucket and when it's full, start it up. You can watch the bucket to make sure you always have water. No water to the cutless bearing so you can't put it in gear. If you disconnect the prop shaft then you could put it in gear. I can only run it fast for a little while or the bucket is sucked dry. At idle the hose will keep up and keep water in the bucket. To winterize on mine (closed cooling) I pour 4 gallons of straight antifreeze in the bucket and suck it up. By the time 4 gallons go in, some is coming out the back. You can hang a bucket on the exhaust and see what is coming out. Good luck, Ed
