Oil Filter Adapter plug?
Posted: Wed May 29, 2019 5:30 pm
by GregM
Should this plug be removed before installing the oil filter adapter? See attachment
Re: Oil Filter Adapter plug?
Posted: Thu May 30, 2019 12:22 pm
by EWRice
That plug stays in. The bypass is built into the filter housing.
Posted: Thu May 30, 2019 5:14 pm
by GregM
Thank you EWRice for the confirmation and piece of mind! This is my second go at replacing the motor I was hoping this wasn't something I over looked on the previous motor that broke a valve that destroyed the piston in cylinder 1. Is it safe to assume that other oil passage plugs that come installed in a rebuilt motor should not need removed?
Posted: Fri May 31, 2019 12:12 pm
by EWRice
The only oil passage that you should have to worry about is the one for the sending unit next to the distributor.
