Oil Pump for 318
GregM
Oil Pump for 318
Postby GregM » Wed Mar 21, 2018 1:05 pm
What oil pump should we be using for a rebuilt 318 marine engine? I am replacing a bad engine and the rebuild didn't come with an oil pump and I don't want to reused the old one. I see standard and high volume but wasn't sure which is more appropriate?
barefoot99
Re: Oil Pump for 318
Postby barefoot99 » Wed Mar 21, 2018 7:28 pm
Standard
SUP !
1982 32 Sedan FB
2072 hrs
360's(rebuilt)-Edelbrocks, DUI
Norris Lake
Speedwell,TN.
Postby EWRice » Wed Mar 21, 2018 7:42 pm
I will second the advice on the standard pump. The high volume will only bypass the filter when cold and cause oil leaks when warm.
Just make sure you clean out the pickup tube and suction screen well. Many a new engine has met an early death from dirty suction screen.
GregM
Postby GregM » Thu Mar 22, 2018 4:45 am
Thank you gents!
