Bilge Blower Restoration
carl
Re: Bilge Blower Restoration
Postby carl » Thu Jul 26, 2018 6:11 am
Of course we are aware and have not forgotten the engines are big air pumps. They will suck the air first. Didn't want to try and calculate the volume required because it is a variable dependent on load or RPM. I only modified the exhaust.
1990 Marinette 32' Sedan Fly Bridge "IKOI"
Twin Crusader 350's (Closed Loop Cooling)
Bow to Stern Full On Restoration in Progress
Chickamauga Lake, Tennessee
A boat is always safe at shore, but that's not what its built for...
carl
Postby carl » Thu Jul 26, 2018 8:07 pm
Today I installed the two Bilge Blower Hose Anchor Plates into the bilge under the aft deck astern of the two fuel tanks, one on the port side and the other on the starboard. I fabricated them out of ½” thick black starboard material and they measure 12" wide by 7" tall. One hose is routed through my bilge blower and the other is passive. Tomorrow I will fabricate two more single hose anchor plates for the remaining two passive hoses. Photos will follow.
carl
Postby carl » Thu Jul 26, 2018 8:08 pm
Port side...
Postby Fastjeff » Fri Jul 27, 2018 6:31 am
On mine, someone who 'worked' on it before me failed to properly secure all those hoses. The Admiral (wife) and I always ran the blowers for 4 to 5 minutes before starting the engines--using a timer--but the blowers did nothing since the hoses were disconnected!
Postby ddependo » Fri Jul 27, 2018 7:18 am
Carl, You are killing me with these Clean Bilge picks.
carl
Postby carl » Tue Jul 31, 2018 6:51 pm
Today I fabricated and installed my two single "Bilge Vent Exhaust Hose Anchoring Plates". These measure 6" x 9" and secure the last two remaining passive 3" hoses in the system.
carl
Postby carl » Tue Jul 31, 2018 6:52 pm
Port side view
carl
Postby carl » Tue Jul 31, 2018 6:53 pm
Starboard side view
Postby Fastjeff » Wed Aug 01, 2018 7:02 am
Can't see how the hoses are CLAMPED to the vents. That's the critical area, so they don't rattle off on you.
carl
Postby carl » Wed Aug 01, 2018 6:39 pm
Jeff brings up a very good point that I should have included in my description of the modification upgrade of the bilge blower hose restoration. If you look closely at the picture attached you will see that there are two black tyraps 180 degrees out from one another securing the bilge blower hose to the collector/plenum boxes. There are two small holes 180 degrees apart in the collector/plenum boxes straddling the 3" hole for the hoses, once you twist two or three spirals of the bilge hose wire into the collector/plenum boxes you cut a small slit (just enough for a tyrap to pass through) in each side of the blower hose itself making sure they are right on target with the two holes in the collector/plenum boxes then you pass a tyrap through the slit into the hose, up and over the two or three spirals of bilge hose you twisted up into the collector/plenum boxes and then back through the hole. Cinching it all together and then cutting off the tyrap tail.
