Fuel System Restoration: Tanks to Carbs...
carl
Postby carl » Sun Jul 08, 2018 10:57 pm
carl
Re: Fuel System Restoration: Tanks to Carbs...
Postby carl » Sun Jul 08, 2018 10:58 pm
carl
Postby carl » Sun Jul 08, 2018 11:01 pm
Postby Fastjeff » Mon Jul 09, 2018 7:14 am
I hope you glued those rubber strips to the tank with 5200 adhesive.
carl
Postby carl » Mon Jul 09, 2018 7:30 am
Postby ddependo » Mon Jul 09, 2018 8:10 am
As I watch Carl's progress it is amazing to see the craftmanship he has put into this 32. It is going to be much better than factory when he gets done. He does everything the right way the same as he would at work for Westinghouse on a power plant. He doesn't get in a hurry. I couldn't even pull him away to go for a boat ride and dinner. It has been a educition being on the same dock . Nice guy.
Postby Fastjeff » Mon Jul 09, 2018 10:44 am
Glad to see you're retaining those Perkos--darn good unit. I use a small mason jar to drain them and check for water/ crud.
carl
Postby carl » Thu Jul 12, 2018 5:16 am
Postby Fastjeff » Fri Jul 13, 2018 7:01 am
When I changed the gages in mine, I deliberately set them up so there was at least 10 gallons of gas in the tanks on 'E'. I know; it's only a psychological thing, but it helps when the marina is a long way off.
Postby ddependo » Fri Jul 13, 2018 3:11 pm
I did that too. Have not run out yet.
