Rudder shaft corossion concern.
martindesign
Postby martindesign » Thu Jun 18, 2015 8:57 pm
So as I fix one issue I find two more. Love boats. :lol: when I first got the boat the steering was frozen. The rudder shafts were frozen in the upper support plate bushing. Grease fittings would not take grease and after some beating and oil soaking I got them sort of freed up. Still some crunching going on. (I though these were stainless).... Now the packing is puking and its all the way tightened down. Actually as I tightened it it got worse. Also felt crunchy. I'm afraid to try repacking if the shaft is pitted cause it'll just eat up the new packing. Sling in and out all the time getting expensive. Anyone ever run into this? Thanks again guys.
Catawba Oh
martindesign
Re: Rudder shaft corossion concern.
Postby martindesign » Thu Jun 18, 2015 9:32 pm
Im found only one picture online that is set up like mine. With the upper greasable plate and it also had hydraulic steering so maybe this was a part of that kit. There is a plate and upper support on mine that it looks like a lot didn't have. Also seems thatcould cause corossion issues.
Catawba Oh
Postby ericinga » Fri Jun 19, 2015 4:31 am
Our boat had the same rudder support configuration. I tore it out. Here's why:
1. It makes the stuffing box difficult to service.
2. I found the plastic stuffing box underneath it. I believe these are brittle and untrustworthy. It's a cheap solution to the better bronze box.
3. The bronze bearing attached to a stainless steel plate creates a grounding path to a steel rudder. This simply makes the rudder a large anode.
Go to blue yacht supply and buy a Buck Algonquin bronze stuffing box. I believe the size is 1" shaft and 2" hose. You'll also need 1/4" packing material. They are $90 each and solves the problem. While your in there, pick up a "betty" bearing by Johnson Duramax and replace the rudder bearing. It will likely need the replacement.
When we bought our boat, the rudder was structurally sound but was rusted through in spots. I believe the reason was the support plate.
Since removing the plate, replacing the bearing and the packing gland, we no longer have rudder wobble or corrosion.
martindesign
Postby martindesign » Fri Jun 19, 2015 7:06 am
Wow. Thank you for the reply. That literally anwsers 100% of my questions. I am gonna do exactly that. Thank you so much!!!
Catawba Oh
martindesign
Postby martindesign » Fri Jun 19, 2015 7:10 am
We're you're rudders salvageable? I'm concerned about too much pitting around the packing to seal.
Catawba Oh
Roger2
Postby Roger2 » Fri Jun 19, 2015 10:26 am
Personally I would stay with the plastic. No bronze.
Roger
Roger Brown
Petersburg, IL
Postby ericinga » Fri Jun 19, 2015 11:52 am
Yeah that makes an abundance of common sense. Let's put 1/32" of plastic between a thousands of water gallons and a boat bilge. My plastic packing gland was so brittle it snapped off with very little movement.
The only contact point in a packing gland is the non-metallic packing material. If properly installed, there is no corrosion issue. This supposed fear of bronze is over blown.
Yes. The rudder was salvageable. Worst case, you can buy a stainless rudder for less than $200.
Roger2
Postby Roger2 » Fri Jun 19, 2015 4:24 pm
My "plastic stuffing box is a lot thicker than 1/32, but it's your boat.
Roger
Roger Brown
Petersburg, IL
Postby bill » Fri Jun 19, 2015 5:35 pm
Martindesign wrote:
" I'm afraid to try repacking if the shaft is pitted cause it'll just eat up the new packing. Sling in and out all the time getting expensive."
I know of someone :oops: who tried repacking in the water :roll: You would be surprised :lol: at how fast that rudder will drop to the bottom of the lake :shock: and how much water comes out of that 1" hole. :o
USCG Master Lic. Retired
Postby barkleydave » Sat Jun 20, 2015 7:14 am
These packing glands are getting hard to find. I believe all the rudders shafts are 1" dia.
http://www.foreandaftmarine.com/18-49409.htm
http://www.westmarine.com/sierra--stuff ... P010529691
http://www.overtons.com/modperl/product ... i?i=749048
I would have to consider going with bronze if I replaced my rudders with new stainless ones. Rudders are never really isolated due to linkage etc. and that is why we put anodes on them.
