water hose
Re: water hose
Post by Tuggle »
1.25" ID is correct, make sure you get rigid water hose, vacuum hose, otherwise the suction from the pump will make it collapse.
ronmar
Re: water hose
Post by ronmar »
Thanks for the input. I was a bit nervous with the coupling idea. I will go ahead and remove and try to match up correct hose type
1990 Marinette 32 Sedan
Marty D
Port of Cincinnati
barefoot99
Re: water hose
Post by barefoot99 »
Get marine hose. Remember that hose sits just below the water line It is 1 1/4" hose
SUP !
1982 32 Sedan FB
2269 hrs
360's-Edelbrocks, DUI
Norris Lake
Speedwell,TN.
