Nautolex - Original White w/Charcoal Stripes
pmoody
Re: Nautolex - Original White w/Charcoal Stripes
Postby pmoody » Sun Mar 11, 2018 12:25 pm
Replacing my aft deck and would definitely have gone original had it been available.
Postby shade2u2 » Sun Mar 11, 2018 8:15 pm
The M that I’m buying comes with some leftover original print Nautalex that was produced as a special order. Supposed to be quite a bit of it. I will let you know what I find out.
1984 28 Express Hardtopw/single 360 1.5:1 drive (SOLD)
Pipercubfan
Postby Pipercubfan » Sat Mar 31, 2018 11:37 am
I am having the floor replaced within few weeks so I don't want to wait for Nautolex to ramp up production. I will have use something else.
Postby TinLizzy » Sat Mar 31, 2018 5:34 pm
I don't know what happened to Verboatn, he hasn't been active on this site since he posted the original thread on the Nautolex. It could have been a hoax from the beginning. I hope not!
yooper
Postby yooper » Mon Apr 02, 2018 12:52 pm
i bought a roll of that stuff to redo my boat 4 years go. I had the New 5/8" sprayed with bed liner instead. I'll take the stuff out of the original shipping roll and measure it. there is nothing on the outside of the package to tell me how much is there. Then I could offer it for sale somewhere on this site. I prefer bed liner.
MetalHead
Postby MetalHead » Tue Apr 03, 2018 7:32 pm
What color bedliner did you use? Was it roll on or spray?
Big BigM 's Rule !!!
yooper
Postby yooper » Wed Apr 04, 2018 11:39 am
Metalhead,
I cut the old cockpit pieces out from the top put them together and made a nice 1/4" luan pattern. You only need one side - flip and you have the other. I made new pieces out of 5/8' outside rated plywood to avoid fitting issues. You don't need marine grade - the deck is flat. I took the wood to a Rhinoliner dealer. The colors were limited so I picked light grey. For about a $100 they sprayed the wood with a nice non-skid overlapping the under side by about 6". They should have more colors now because they do a lot of business spraying car/truck bodies. Hacking the old pieces out from the top was no problem. Screwing the new pieces in from the bottom can be difficult unless you have freaky long arms. I replaced the rusted out main washer on the original shower type scuppers with a big shaped aluminum diamond plate that fit underneath the cockpit corner side walls. Tighten the big drain nut and it clamps the deck down hard in each back corner. Since the front is clamped under the door sill that just left the rest. I only replaced the bottom up screws that I could easily reach. Once I did that the deck was secure. I would have used top down screws if they were needed. I never replaced the hatch trim. I cut my arm when I fell against the open hatch edge and had to go to the hospital. An open hatch like that is like a big sword. Just use a rubber rug. The Rhinoliner held up as I pounded on it redoing the project boat. It looks like new.
Pipercubfan
Postby Pipercubfan » Sat Apr 14, 2018 9:09 am
Sorry to late for me . We just ordered new material for the new flooring.
SunbeamIV
Postby SunbeamIV » Fri Apr 27, 2018 10:06 am
Source for 5/8” marine plywood:
Toledo Plywood, 1011 N. Westwood Ave, Toledo OH 43607
$ 66.95 a sheet
Could still use some new original style white teak Nautolex!
Located: Edgewater Yacht Club
Lake Erie
BIGMEXPRESS28
Postby BIGMEXPRESS28 » Sat Apr 28, 2018 9:46 pm
I would love to be able to buy some of the original design
