Stumped - Fuel Delivery Issue
fpc310
Re: Stumped - Fuel Delivery Issue
Postby fpc310 » Wed Sep 25, 2019 7:25 am
I have a Sierra screw on style fuel filter. The Perko has been removed just to rule that out. Thanks for the suggestions from everyone. I finished off my already dying starter in this process, so it’s getting rebuilt / replaced now. I’ll try some of the recommendations next week.
Todd
1983 32’ SedanFlybridge
Twin 318 Chryslers.
Wardog
Postby Wardog » Sat Sep 28, 2019 4:52 pm
I couldn't tell from your question if you replaced fuel pump was electric or engine mounted..i was having almost the same issue. I switched to electric fuel pump always have fuel pumping thru fuel lines and separator as soon as you turn on key...good luck..i have 318s
Wardog
1968 marinette
318s 225hp
ALKINDA
GOOSEPOND
fpc310
Postby fpc310 » Tue Oct 01, 2019 3:54 pm
Ok. To close out this issue... the brand new Sierra mechanical fuel pump was shot after a couple hours of running. In the process of trying to start the motor, I fried the starter solenoid and possibly the battery too. Either way, I replace the solenoid with the spare, new fuel pump, checked the anti-siphon valve, all fuel lines, new filters. Also rebuilt the starter for $30 (thanks Lakeland auto in Port Clinton OH). The new pump is moving fuel nicely. I guess the moral of this story is to not run the starter for too long chasing a fuel issue. Also don’t trust new parts... they may fail faster than you think. Thanks for all of the advice.
Todd
Twin 318 Chryslers.
Postby Fastjeff » Wed Oct 02, 2019 6:40 am
..."Also don’t trust new parts"
Right on, brother! I had a virtually new fuel pump start leaking like crazy--bad weld on the outlet fitting. Nearly lost everything (including our lives).
