Page 2 of 3
Re: V drive question
Posted: Thu Jul 05, 2018 7:08 pm
by Hiramsaint
barefoot99 wrote:on 32's in 1985 or 86 they switched to 1.5 to 1 velvet drive transmissions. All the 32's before(1970- 1984) that and most smaller M's have the 1 to 1 and run a 14 " prop. Both shaft sizes were used.
Good luck M's rock !
I understand ratios but is there any benefits to one over the other. The reason for the question is: we are planning at least a half "loop" trip in the near future. I'm wanting to be able to do a slow cruise so we can soak up the experience and the sights, get decent fuel economy but be able to kick it up a notch if necessary ( storm, sickness, emergency, ETC.). I've heard dual engines are preferable but the only reason I've heard so far is for docking and redundancy. I believe for my purposes a single would be fine but either will work for me. I really have no cruiser experience so forgive my ignorance, I'm attempting to fix that. My only experience so far is with a number of smaller runabout's and a 34' Drifter houseboat we tooled around on Lake Allatoona with for 10 years--they were all outboards.
Posted: Thu Jul 05, 2018 7:41 pm
by Hiramsaint
Fastjeff wrote:.." I'm looking at a 28' with dual 318's and 1:1 V-drives."
I thought that's what the ad said but no worries, the ad is gone now as I suspected it would. It's okay, there's plenty more out there so the hunt can continue.
Posted: Sun Jul 08, 2018 10:19 pm
by Wilfred
Confusion between V-drive and Velvet Drive
Posted: Mon Jul 09, 2018 7:15 am
Ahhhh!
Posted: Mon Jul 09, 2018 1:46 pm
by Hiramsaint
Yes...my ignorance is on full display. Is there a quick laymans explanation of the difference between the two?
Posted: Mon Jul 09, 2018 6:00 pm
by EWRice
Sometimes the v drive gearbox is bolted directly to the transmission. Sometimes it is connected to the transmission (or engine in race applications) by a driveshaft.
Posted: Mon Jul 09, 2018 6:32 pm
by Hiramsaint
So, am I correct in thinking that a velvet drive is more of a direct drive and a V-drive is a 180* reduction drive of sorts?
Posted: Mon Jul 09, 2018 6:51 pm
by EWRice
Velvet drive is a division of borg warner. They make both conventional inline transmissions and v drives.
Both inline and v drives can be 1:1 ratio or any number of reduction ratios. Some v drives actually have an overdrive ratio.
Posted: Mon Jul 09, 2018 9:14 pm
by Hiramsaint
Thanks for the help fellas. I'm still not quite getting but I will research so when I buy, I'll know what I'm buying.
Posted: Mon Jul 09, 2018 11:55 pm
by Rockit
The only BigMs that (to my knowledge anyway) came with v-drives are the houseboats (a/k/a "river cruisers"). With a V-drive the front of the engine faces the stern so the output shaft faces forward. The actual v-drive has an input shaft on top mated to the engine/transmission and the output is attached to the propeller shaft.
I tried to attach some images so you get the idea, but if you google "v-drive boat" you will see similar images.
The advantage to a v-drive is the engine can be placed farther aft though in most designs that isn't really an advantage. Inboard houseboats are usually v-drives as are some ski boats.
The BigM s had velvet drive transmissions so someone may be confusing that with the v-drive.
I hope this is helpful.
