Oil pump torque?
Posted: Sat Apr 14, 2018 1:51 pm
by GregM
I am putting a new oil pump on rebuilt 318 engine and the spec's say 35lbs. That sounds kind of light for something I really don't want to come loose once I have the engine back in the boat. I put some high temp lock tight on them. How tight do you guys recommend?
Re: Oil pump torque?
Posted: Sat Apr 14, 2018 7:31 pm
by EWRice
Go by the book. 35lbs sounds right. I have never seen an oil pump come loose, ever.
Posted: Sun Apr 15, 2018 7:08 am
For your piece of mind, you could Lock Tite the bolts.
Posted: Sun Apr 15, 2018 6:18 pm
by Busia
Go by the size not the purpose of the bolt or cap screw. Rule of thumb is people over tighten little bolts and under tighten big ones. I have fought Loctite that the factory used, so I don't use it much. If the bolts are important, just safety them. Drill the heads or get drilled bolts and safety wire them, or use a plate under them with a tab that will bend up against the flat of the head, or with nuts and bolts use a castellated nut and a cotter key
