Spark Plug Wires
Posted: Sat Sep 09, 2017 9:49 pm
by honestcharlie56
I usually see people complaining about the stock style spark plug wires. I bought a universal set with 90* plug ends and they fit great. Of course, you still have to cut the wires to fit and terminate the distributor end. See below!!
https://www.amazon.com/gp/product/B000A ... UTF8&psc=1
Re: Spark Plug Wires
Posted: Sun Sep 10, 2017 6:58 am
Looks good. Did you go under the manifolds or stuff the wires between the manifolds and valve covers?
Posted: Sun Sep 10, 2017 7:51 am
by honestcharlie56
Not only were the original wires corroded from the, as you have seen, sinking.....but I couldn't stand the fact that they were stuffed in there and hardly serviceable. They made breaking in an engine quite difficult, as I really like to plug the plugs often to check whats going on inside the cylinders. So I got these to route them outside of the manifolds. Just like you have recommended on both this site and the Marine Engine Forum. If we can get you on "The Hull Truth", Fast Jeff will be everywhere.
I'll take some pictures this morning when I go to the boat.
Posted: Sun Sep 10, 2017 9:22 am
by bcassedy
Not being a true "gear head" but more of a "shade tree mechanic" (tuff to do on a boat! :-) )...
Is there a downside to routing plug wires on the outside of the manifolds (length more than heat)?
Posted: Sun Sep 10, 2017 8:56 pm
by honestcharlie56
I don't think so, but couldn't objectively prove it one way or the other. Mine are working fine though. Took a two hour cruise and checked the plugs, they looked great.
Posted: Mon Sep 11, 2017 6:02 am
The strongest DIS-advantage to the factory wiring mess is it's very easy to confuse the wires.
The marina guys did that to me (during an insurance settlement deal) and it drove me nuts trying to cure a backfire under throttle. Changed all kind sort things before finding they had two plug wires reversed. (Dopey me; I should have done the 'pull one wire at a time from the distributor' test.)
All in all, much easy to work on the motor with the wire outside the manifolds.
Posted: Mon Sep 11, 2017 8:01 am
by honestcharlie56
Yes sir! I can easily pull one wire off, pull the plug, and then reinstall in no time flat. Used to have to sit there and fight the plug wires
Posted: Mon Sep 11, 2017 9:30 am
by jmonday
Does anyone know of a set of wires pre-built that work outside the manifolds?? I have seen a couple of people what say big block chevy wire set do but really would like the part number if anyone has the info.(Mine run outside and I like it much better than the factory setup.)
Posted: Sat Nov 11, 2017 9:15 pm
by honestcharlie56
The set I posted originally are extremely easy to cut and fit.
Posted: Mon Mar 26, 2018 6:24 am
by Trowerpower
Performance Distributors (DUI) out of Memphis, Tn. Has excellent spark plug wires. Ordered mine four inches longer than an automotive 318 with straight spark plug boots. They fit perfect routing through the exhaust manifold openings. Check out their distributors when you go to their website. They were $99 a set a few years ago.
