Fel-Pro Gaskets
ericinga
Fel-Pro Gaskets
Post by ericinga »
If you ever need engine gaskets, you can call Fel-Pro or post in their on-line forum. They are very responsive.
http://www.felpro-only.com/break_room_forum/
I was able to order the top end gasket set for our 318, #17250, through Autozone. The set ships direct from the Fel-Pro warehouse and are a next day delivery. Cost was $134. Standard automotive gasket set was something like $85. There is a big difference between the two gasket sets. The manager tried to convince me to take the in stock automotive set rather than wait. I decided to wait.
FWIW - the lower end gasket set, called the overhaul set, is #17150.
Exhaust riser gaskets (center risers) are #17552.
Lifters are Melling part number JB-2011.
Parts from ebasicpower.com:
LH camshaft is Melling part number MEL23103
RH camshaft is Melling part number MEL23104
Timing Chain set is Melling part number MEL40406
Eric Spies
1989 32 SDFB
Lake Lanier, GA
Marinette Boat
