Mechanical fuel pumps
Postby bcassedy » Wed Jun 12, 2019 9:01 am
For an '88 Chrysler 318cu in engine - Go2Marine.com
https://www.go2marine.com/product/85333 ... -7254.html
'88 32' Sedan Bridge
Twin 318cu in Chrysler
1.5:1 Velvet drive trannies
Fresh water only
BobCav
Re: Mechanical fuel pumps
Postby BobCav » Wed Jun 12, 2019 11:41 am
I found the same one on Amazon for $80.... it's the one on my engine now.
Mechanical Fuel Pump 3745414 https://www.amazon.com/dp/B07K65J22Q/re ... aDb7N8Y6DZ
1974 28' Express, Single 318
Currently being restored, eventually on Potomac and Chesapeake Bay
Follow my restoration on FB @ThisOldBoat at https://www.facebook.com/ThisOldBoat
Postby bill » Tue Mar 31, 2020 6:58 am
Thanks javalin390
Carter fuel pumps
Unread postby javalin390 » Sun Mar 22, 2020 8:23 pm
Hello all ! Here's some info some of you may be able to use. I know many of the Chrysler powered M's had Carter fuel pumps, and many of the 80's models had the type that were not serviceable, but...if yours has the older style that can be dis-assembled, I have found a good kit to re-build it. A company call Then & Now Automotive offers a kit for the old Mopars. The web site is difficult to navigate, so I called and ordered direct from them. The kit number is #CK-114, comes with new diaphragm, 3 new check valves, gaskets, pins, etc... They even have a YouTube video on it, very easy rebuild. Although their video is showing a Ford pump rebuild, it's the same pump (Carter supplied many manufacturers). The hardest part of it was crawling below deck and pulling the pumps off ! Costs a lot less than new pumps too.
http://www.then-now-auto.com/fuel-pump-repair-kits/
https://www.youtube.com/watch?v=DyiK206YRQU
USCG Master Lic. Retired
