Found this on craigslist in NJ
https://jerseyshore.craigslist.org/boa/ ... 48632.html
One of the Last Ones
Re: One of the Last Ones
Alson note that someone cut a transom door into her as well. Even has a cedar closet!!
Have seen other 34s with the transom door. I think that was the factory's (Harbor Master?) attempt to make the Marinette more refined/modern/convenient before ultimately ceasing production. Similar to the Marquis line that Marinette produced in the late 80's.
It would be nice to see one of these in person. I wonder if it has the same canoe style hull as the previous Marinettes. Curious how it handles in a chop.
Forum member since 1998.
Transom door was stock from the factory on the Marquis Convertibles (sedans). I have a 41. They only built about 8 or 9 of the 41 sedans. Even less of the 34 sedans. But yes the transom door was factory.....
Cool boat. IF the bottom is good, it is a great find.
Yes the same bottom design as the 32, just longer and wider
454 Crusaders
454 Crusaders
Nope Factoryjavalin390 wrote: ↑Fri Sep 02, 2022 8:44 pm Alson note that someone cut a transom door into her as well. Even has a cedar closet!!
454 Crusaders
454 Crusaders
